Help With 3CX server with PFsense
techs221
Hello All
I am in need of some help I had to change my server to a new box and I can not get my phone server outside of my lan I have forwarded all ports that I need to I think, I have tried everything I can think of
I am running though a PFSENSE firewall and can not get my firewall checker to pass or get access outside of internal network
I have included screen shots. any help would be awesome
Try changing the outbound NAT method to Manual (The radio buttons above the outbound NAT policies) - That's how i set all mine and have no issues
Hope this helps!
You can make it work in Hybrid mode, as manual rules take priority. Add a new NAT rule as follows:
Source: Your 3cx internal IP
Destination: Any
NAT: WAN Interface/IP
Static NAT Port (This is the important one)
Without the static nat port 9500 gets translated to something else, as shown in your checker screenshots, static nat port means 9500 etc will equal 9500.
Update: Image attached, I use OPNSense which is a pfSense fork, same same when it comes to NAT configuration.
ok that fixed some of the firewall checker what about these parts
and I am not sure if this is related or not but I can not make outgoing phone calls and if someone calls in i can hear them they just can not hear me
on pfsense for 5060 use UDP or both, UDP/TCP, for 5090 use both UDP/TCP.
Then try firewall checker again
ok now I lost all the porting mapping for the 9000-9500 all fails again
here is what it looks like now
We did setup like the below for a customer, and it is working, look at the Outbound NAT Mode, and the specifik internal server IP.
I mean that when creating the Roules, you was able to click on a "Create Coorsponding Roule" and select this.
Hope it helps, I´m not able to help further as I dont have access to the router anymore.
aatroxadrian
