Hidden Group Members are shown in Contacts of Android and iOS
bbinz
Has anyone had this issue.
For a Group, I have removed all the check mark on the options in Group Rights.
Any members of this group are not visible in the Status tab of Android and iOS or webclient.
However in the Contacts tab of Android and iOS they are visible.
This is defeating the purpose of hiding extensions
Regards
bbinz
You cant specifically prevent someone from accessing the contact list but you can remove someone from the contact list by enabling the "Hide this extension from 3CX company phonebook and 3CX Apps" under Extensions >> Edit >> Options. So, if you do this for everyone, no one will be able to see anyone in their contact list.
SupportRock
