Solved Holiday message and redirect to Voicemail
lextar
Hi all,
is there a way to redirect the users to a voicemail after the global holiday message is played?
I need to let the people leave a voicemail during the holidays period.
Yes go to digital receptionist HOL and set the timeout value to 2 seconds and the destination to the voicemail box you want.
Hello @lextar
In addition to what @CentrexJ suggested make sure that under your trunk settings you have enabled the option "Play holiday prompt when it's a global holiday"
Reactions: lextar
Either do what suggested or create a CFD :)
Dan
Thanks!
It worked ;)
Glad to see the issue has been resolved
Bluebox Global
