Solved Hosted 3cx registering with different IPs
mistersoliz
Hello all,
I have an instance that is registering with my SIP endpoint (telnyx) with multiple IPs every couple of minutes. Is this normal behavior?
I managed to fix the issue last night by sending all traffic to the PBX FQDN, but I was under the impression that the hosted instances are static IPs.
I guess my question is: Am I wrong for thinking that they are static IPs?
Is that the proper way to handle the traffic since the registrations kept going to different IPs?
TIA
Reactions: AndreasY_3CX
@mistersoliz ip addresses are static.
PM me with your subscription key because I suspect you have another machine with the same
key which is alive at the moment and get the ip address of your FQDN.
Reactions: mistersoliz
Hi @mistersoliz,
Yes, your assumption is correct. We do use only static IP addresses for the hosted 3CX systems.
I am under the assumption that your subscription has 2 instances running with the same FQDN and thus your FQDN is not stable with a single IP address.
Egg on my face. I forgot I had self hosted this PBX before migrating to 3CX hosted. I just destroyed that old VM.
I need a break >_<
Thanks all
Please make sure that you restart all PBX services on your 3CX hosted system in order for your FQDN to rebind with your 3CX hosted IP address.
Bluebox Global
