HostProfis SMS Setup on 18.0
winspro
I'm trying to setup SMS on our 3CX 18.0. Before version 18.0 the setup for SMS was different and there was a dedicated option for "HostProfis SMS":
Now, on version 18.0 there is no such option. After creating a new Trunk for "HostProfis" (AT) there is no SMS Tab.
How can I setup SMS for HostProfis (as mentioned in this 3CX-Blog Post)?
If the SIP Trunk template for that provider has not yet been update for the new SMS implementation, it will not work.
Maybe you can ask your provider if they have an updated version you could put manually on your server.
This would also require re-creating your trunks or manually change a value in DN properties.
Kindly,
mbar
