How do I change the default landing page?
RustBoy
New User
Where is the setting that dictates the landing page after admin log in?
When I log in as the admin on one of our Elastix systems it takes me to the (PBX/Users) page. On our second system it takes me to the (System/Dashboard) page.
why don't you check the ssl_access_log on each after you have logged in to see if you are being served a different directory or things have been altered in some way
if both the same check the index file in the path on each server, maybe someone was moving files and had an error in judgement
system tab is the default on all the installs I have done
/var/log/httpd is the place to start on the web server logs
I don't understand your reply.
I am looking for the option that allows me to change what the landing page is. Is there such an option? If not, what file can I edit to change it manually?
I don't think there is a setting or configuration in the GUI.
Not sure how you changed yours.
Check what the files look like.
Best hint is to go look at the logs for the webserver on each machine. If you have a difference between two boxes you should be able to see if it is pulling a different directory structure or if the files themselves as been altered. The logs should show you the access by your IP and to what.
Settings for default page would be a webserver setting. So if completely confused you may want to do some searches related to configuring apache.
Edit the file /var/www/html/index.php
Goto Line number 98 and change "Location: index.php" to "Location: index.php?menu=pbxconfig"
Apollo Cloud
