How get more storage for Disk Usage
chimac07
I have v8 running with 150 GB for recording storage. I would like to increase the recording storage to around 3 terabyte. I would I go about doing that? (Would I need to connect my 3cx to a cloud storage? If yes, how would I connect my 3cx to a cloud storage?)
Recording location has to be local. So you should speak with cloud provider or look at getting yourself bigger drives if your install is local.
Hi @chimac07,
To second what @kieferschild said, if your local storage disk is small, then you may want to archive more often to a larger archive disk in the cloud but as he says, recording location must be local so without regular archiving you'd have to increase the size of the local disk.
megalmazan
