Solved How to barge in a call?
JCubio
Hi all,
How can I barge in a call?
I already enable the barge call option from the group and extension options.
I've read in the forum that I just need to right-click a live call and select Listen, Whisper or Barge.
But I can't see these options. Did I miss the configuration somewhere?
12933
Hi all,
Users need to be in the same group.
Also, a Pro or Enterprise license is required.
Yes, these conditions are already met.
Oh, just noticed. Don't right click the user itself, left click on the blue box containing the caller ID. Then you'll have a menu to barge-in, spy, drop or transfer the call.
Reactions: accentlogic
Hi Sir,
I just found out that the options don't appear with right-click. Instead, it appears in left click
Hi Sir,
Right click is for the contact box.
Glad to see the issue has been resolved
Kayla Norris
