How to Change 3CX Media Server (RTP) - 9000-10999 (udp) Ports
MARIGLENCULLHAJJ
New User
Dear Sir Madam
Is it possible to change these ports ranges, because I run multiple 3cx system inside one static Public ip address.
All the best
There used to be a 3CX version that supported multiple PBXs and did use a different range for each. I'm not aware of any way to change this currently, as each instance is designed to run behind it's own, unique, public IP. You may have to pay for some additional IPs, to have all 3 work correctly..
Hello @leejor , Thank you very much for your replay,
I just changed the ports that 3cx asks during the initial phase, it is working but I wish I have no problems later because of rtp ports.
All the best .
hrhrohit
