How to connect Nerim SIP peering with V11
direct
Hello I need some help
I can't (yet) manage to register a French (Nerim SIP peering trunk, without authentication) on a V11 3cx PABX.
V11 has no support, we cannot upgrade because higher versions no longer have a Hotel module. in short, we are screwed.
Up to now:
Nerim template finally loaded and provider created, seems to register but does not work.
The big question is can it work on V11?
Is there a difference between good old SIP trunck and Nerim SIP peering?
Any suggestions/help is welcome,
Regards Victor
What was specific in V11 hotel module? in V16 there is hotel services , i don't use it but may be it is same as what it was in V11?
11779
For trunk no idea if there's so much change , Do you have some logs to see what happens ?
Congratulations , first post in ten years registred on forum o_O you are god:):p
I would assume that 3CX version 11, (or previous versions) have been running for them, without issues, up to this point. That's a good thing. Not something to make fun of.
Perhaps they actually do a search through the forums, and found solutions, posted by others, without having to post themselves.
@leejor , Yes we can make fun with everything , life is too short to have serious things done with bad mood everyday , complaining about everything, not so much sense of humour tonight? don't search things i never thought ;)
Smax
