Solved how to deactivate a user in microsoft 365 and 3CX in same time
Hubi40
It is possible to deactivate a user in microsoft 365 and 3CX in same time in the V20 ?
If not, did have API for that ?
It is possible to disable users from the Azure portal, which will disable the synced 3cx user.
Thank you Charles for the quick response !!
You are welcome.
KylieWilderman
