Solved How to host multiple 3CX servers under one IP?
greychain
Gold Partner
Other systems can use OpenSIPS to achieve this, how can this be done with 3CX?
@greychain this is not possible..
If you want to setup multiple 3CX Systems you may spin machines in 3CX Hosted environment and you are good to go !! Dedicated machines for each PBX.
This is so true, we had to buy a /24 to host all our systems.
@GlobalSiteGuard what I can recommend is to host with 3CX and you won't have to worry about any of these things at all ;)
If I could see a revenue stream from this I might consider it.
@greychain you may speak with your Sales Rep about this..
I did, they said I should sell other services.
devo.it
