How to limit time call on 1 month.
HoangDV
Hi all, i'm new on 3cx, my business department have a question about limit time call on 1 month.
example : Staff A have just only 100 minutes call external / 1 month. If he overpass so 3cx will stop call external.
Please response me ASAP
Thank all.
There is no option to block calls if a limit is reached.
Hello @HoangDV
As mentioned there is no way to limit external calls when a time limit is reached. You could however post your idea on https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
One option would be to create a service that processes the CDR files. The CDR files include the duration of a call. When an employee has reached their limit, you could use the Call Control API to disable external calls for this extension, then when a new month starts, the service could go back in and re-enable the extensions. This is absolutely possible to do with a little programming.
megalmazan
