How to setup Yay.com
JackMozza
New User
Could anyone give me some instructions for setting up Yay.com with 3CX as Yay support basically they said find out your self.
Hi @JackMozza
They seem very helpful :) Well since the are not a supported 3CX Voip provider we do not know the details on how the set them up in 3CX either. So my first suggestion is to use a 3CX supported provider which has been tested and all configuration is known.
If that is not an option then perhaps another forum users has Yay already running and can offer some assistance.
Hi Jack,
Just use the Generic template, and Enter username/password which is provided by yay.com and use server, proxy as talk.yay.com. then click "OK". it will be green UP.
Thanks,
RA.
I guess not so much yay?
What is it that yay offers you that 3CX doesnt that you require?
All you need is a SIP Trunk - looks like yay is it's own phone system.
Looks like they offer a SIP trunking feature at the bottom. Their pricing looks pretty expensive as well.
Reactions: [email protected]
Senergia
