Solved How to specify the field in a select statement that retrieves multiple fields?
erpardeiro
Hi guys!
I'm running a select query on a database that retrieves 3 fields (idContato, NumeroContato, and StatusContato).
Within the CallFlow, I need to retrieve the information for each field, but I'm unsure how to do that. Here's the table:
Now, let's take a look at the objects in the CallFlow:
Lastly, let's examine the object (Dialer) where I need to specify that I want to read the "NumeroContato" field.
In this example (Make call from), how can I point to the "NumeroContato" field?
You need to change the statement type to Query, and then use the function GET_TABLE_CELL_VALUE to get each value, for example:
GET_TABLE_CELL_VALUE(RetornaNumber.QueryResult,0,0): will return the value from row 0 column 0.
GET_TABLE_CELL_VALUE(RetornaNumber.QueryResult,0,1): will return the value from row 0 column 1.
GET_TABLE_CELL_VALUE(RetornaNumber.QueryResult,0,2): will return the value from row 0 column 2.
More information on this function here:
https://www.3cx.com/docs/manual/cfd-prompts-expressions/#h.v17ic2wxant9
Thank you very much!
Reactions: edossantos
@erpardeiro
We are glad to hear the issue is resolved.
amazingbv
