Solved How to transfer without a 'transfer' button
jkoop
Hello world!
I have a VOIP to POTS thing that I got working with 3CX a few days ago. Being a POTS phone, it has only the ten numbers, *, and #. Is there a star code I can use to transfer someone from within the company (not mobile agent service)?
Thanks,
JKoop
I assume you are using the phone with an ATA. The transfer function would be a function of the ATA. In most cases, a hook flash will result in a second dialtone The extension can be dialled and attended transfer done. Most ATAs have a star code (dialled after a flash), to allow a blind transfer. Check the ATA manual as the code can vary.
Reactions: NickD_3CX
Thanks. I'll look into that.
JKoop
ICTSupport@bedfordgirlssc
