hubspot crm integration call pop-ups
betel
Are you using the server-side CRM integration? Also, what format do you store your numbers in the CRM and what format does your provider sends on incoming calls?
Reactions: edossantos
Are you using the server-side CRM integration? Yes
Also, what format do you store your numbers in the CRM, and what format does your provider sends on incoming calls? 10 digits format without the +
Let's go step by step. First, let's check that the integration is properly configured. Please go to the 3CX Console > Settings > CRM > Test button, enter a phone number that should be present in the CRM, and run the test. Do you see the contact result?
Yes it works well. The number is entered as a new contact with the number with 10 digits formet. But cannot trigger Popup windows when the call is entering.
Thanks a lot!!!
