Solved Hubspot Integration Problems
walsermedia
We use hubspot and had 3cx crm integration working for years now.
However, the integration doesn't work properly anymore. The problem is in the query:
When entering a swiss or liechtenstein number, formatted like +41 81 123 45 67 or +423 123 45 67 the query will only pass the following values:
+41 81 123 45 67 = "value":"234567"
+423 123 45 67= "value":"234567"
So the number is shortened.
The template is attached.
Thank you in advance
First of, that's a setting for the length passed to the API (Advanced > Contacts > Options > Match X digits/Match exactly.) Set that to at least 9.
As for the numbers, they need to be saved as E164 or at least in one value, not separated by -, (, ), or a space. So, "+423 123 45 67" should be "+4231234567".
Reactions: edossantos
Thank you guys!
"Match exactly" solved the problem.
Finatra.us
