Hubspot integration
Federico80
New User
Hello everybody,
I use 3cx hosted.
I'm trying to integrate hubspot by following the guide https://www.3cx.com/docs/hubspot-pbx-crm-integration/
I can't find the setting In 3CX Management Console go to “Settings”> “CRM Integration”> “Server Side” tab.
Do I need to enable it or it is not active on the hosted service?
thanks to all
You need a Pro or Enterprise license to use the CRM Integration. The tab won't show because of that.
If you used the free upgrade, simply go to the Dashboard, and beside the license key edition, there should be a refresh button. Use that.
Reactions: edossantos
KylieWilderman
