I am looking for a partner with twilio experience. I need a new install that can be done remotely
michaelh76
I purchased a new windows 10 computer.
I need to use the 3cx product. I have dedicated ips
This machine is on the Local Network 192.168.0.29
Every-time I tried to play with 3cx it wants to pick the dedicated ip gateway and that cant happen
here is the Comcast info and I have XX.XX.XX.XX setup with a NAT in the router to 192.168.0.29
I need 3cx installed and setup with twilio and 2 port set up that I can use a Centos box to connect and send and receive txt
I can set this up so you can remotely login and install and configure
If I understand your post, you have two connections - internet and one that you want to use for twilio
Have a look at this post , may help you https://www.3cx.com/blog/docs/network-configurations-supported-3cx-phone-system/
Setup persistent static routes to force sip traffic down the network card that connected to centos - one without gateway https://www.howtogeek.com/howto/windows/adding-a-tcpip-route-to-the-windows-routing-table
Static route will be based on the destination IP address
If the above is incorrect, please explain your network in more details
Reactions: NickD_3CX
gmacinit
