I can hear other side but they can't hear me
InetGuy
I have a grandstream gxp2135 that I have provisioned and I can dial out just fine. I can hear the person on the other end just fine, but no matter what I try, they cannot hear me. I've tried a different phone, I've tried a different codec, neither work. I've also tried using the 3CX SIP app, and that works fine. However, when using the phone, no such luck.
Is there something i'm missing?
You can try enabling "PBX delivers audio" in the Extensions Options menu for both extensions and see if that helps.
Also, disable SIP ALG in your router.
Reactions: YiannisH_3CX
This is normally going to be a firewall/network issue. So either port forwarding of audio ports has not been done or firewall rules (remote ends firewall blocking the inbound connection).
SIP ALG is always a good one to check also, depending on the firewall brand this can be a tick box in the GUI or sometimes a hidden CLI command.
Hello @InetGuy
You did not mention if the phone is provisioned as a local or a remote device. If remote are you using STUN or SBC?
Reactions: eddv123
zipman
