Solved I can't get Click to Call edge extension to work if I use the PWA
gregsmith0
Basically, if I uninstall the Desktop App and use the PWA instead (which appears to be what you are asking for users to do after the latest update), I can't work out how to make click to call work. Should it? or is this a piece of work in development?
Hi @gregsmith0,
Have you set up your Click2Call options by entering in your https://FQDN:port/webclient/ as shown below?
If you've done this and you have your PWA client open, but not the web client then clicking any links will open in the PWA dialer.
Reactions: nikfpic
Fixed Thanks
Reactions: VasilisV_3CX
Excellent! Glad to hear it @gregsmith0! Feel free to open a new thread if you require anything else!
megalmazan
