Identify Extensions in Elastix
oscquin
I have an elastix 2.3 trunked by E1 with a panasonic D500 using Qsig.
Everything works great. I need to add the following feature:
When the analog extensions dial an IP extension (through the E1 trunk) I would like Elastix to be able to identify the incoming number and match it with a list (maybe some text list) where I could add the name of that extension.
I hope I make myself clear on this and elastix able to do it.
Help appreciated.
You should look for 'Caller ID Lookup Sources' and 'AddresBook', and see if they suits you.
Regards,
Claudio
yarusemiKK
