Hi I have checked the configuration and I realized that the provider URL field is not showing in SMS configuration tab what should i do now?The only other advice I can give you is to double check your settings, and that the Telnyx API key and provider URL are correct. There isn't much else to check when it comes to SMS.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
