Import 150 Hotdesking phones
Mickel den Ouden
For a customer i need to import 150 Yealink T31P phones as hotdesking phones
For users i can use a CSV file but is it also possible to do it for hotdesking phones (there is no user)
3cx Version 20 Pro edition (Version 20.0 Update 10 (Build 1785 Release - AI 1.6.91)
Hi, unfortunately there is not bulk option for Hotdesking Phones.
Solution
Oke clear.
Can hotdesking phones be provisioned via 3cx Remote provisioning Server RPS?
I tried this but the phone stays on the change password screen after restart.
The phone is visible in PnP phones but I can not assign them because it says instandly.
"The device is already assigned to a User HD00001. Please delete the phone and try again."
If I delete the phone and restart the phone it wil be back in the PnP phones.
I am using a local SBC on a windows machine.
Hi @Mickel den Ouden yes RPS is supported.
  • Check this document regarding the hotdesking provisioning.
  • Make sure the phone is using the supported firmware
  • Factory-reset your phone; once it reboots, it will automatically provision through RPS (Remote Provisioning Server)
  • If your phone does not support RPS, use manual provisioning; for more information see Supported IP Phones
  • Hotdesking is supported for local provisioning or behind a 3CX SBC. If they are remote, make sure you have a connected 3CX SBC.
malo
