Inbound Rules CID
SpeedyPH
Is there a way to send all inbound numbers from an area code to voicemail? I want to send all 800 and 877 numbers to voicemail.
Thank you,
Andrew
I may be wrong, but I don't believe you can use a wildcard after a set of digits, which is what you'd require, in the CID rules. I have seen some legitimate calls using a toll free number, as CID, so you may be blocking more that you hope to.
Depending on when the CID rule is applied, pre, or post digit manipulation, you might try reformatting the caller ID for any 800 number, changing it into a fixed number, then a single rule might work.
https://www.3cx.com/docs/cid-reformatting/
I have not tested this, so , as I say, it will depend upon the CID rule not being applied until after you have changed the CID.
AshleyStokes
