Inbound Rules Global
Michael Cole
Is there an option to set global rules that work across multiple trunks? Every instance of a PBX has multiple trunks for redundancy and it does get tiring having to configure the inbound rules on a per trunk basis. Thoughts, ideas, things I am doing wrong?
Not to the best of my knowledge. Each CID rule can only be applied to one trunk and DID is for a specific number.
You could always export the setting for one trunk, modify the file and import it back into 3cx
Also if you add your DIDs in your trunk and you do not configure Inbound rules for each DID all calls to all DIDs will be routed to the main trunk number destination which might be useful to some scenarios.
Senergia
