Incoming calls interrupting dial out sequence
colinuk
When in the process of dialling out - before you send/ connect - an incoming call will interrupt the sequence and take precedence, you then cannot continue to dial out until someone in the group picks up the incoming call - then in most cases you can proceed where you left off
Is there a way to block incoming calls once you have started that dial sequence - or lifted the receiver?
Self Hosted
Busy small recruitment agency
3CX 8SC Pro
Predominantly use Fanvil X5u but also happening on mobile App
Incoming call Queue - Ring All
DejanMDS
