Solved Installation help!
chrisjako
It would appear at some point during the install process the 3cx pbx is not being installed, are you using the 3CX Debian ISO? On what platform are you installing?
Reactions: ChrisC_3CX
Using a dell r630 server with the iso off 3CX login, booting direct off a usb as a fresh install
Ok problem solved, I allowed auto dhcp and then setup manual ip, pressed escape during host name and now it’s picked up the preconfigured install
Good to here
devo.it
