Instance Manager not showing logs
Josh@Kelty
Hello, I just activated my instance manager for several of the systems I manage and when I go into them, there are three toggle switches on the right hand side; "Toggle History", "Show Actions", and "Show Log".
The top two work no problem but the "Show Log" switch is grayed out and I cannot click it. Can anyone tell me how to enable this?
Have you enabled them under Settings - Instance Manager ?
Yes, everything is checked off.
[email protected].
