rbergthold Silver Partner Advanced Certified Joined Aug 24, 2021 Messages 159 Reaction score 37 Jul 10, 2025 #1 is there a way in Version 20 to adjust Inter Digit Timer for Yealink SIP-T46U phones?
SweetAction 3CX MVP Gold Partner Joined Jan 19, 2018 Messages 3,462 Reaction score 2,321 Jul 10, 2025 #2 Only with a custom template.
rbergthold Silver Partner Advanced Certified Joined Aug 24, 2021 Messages 159 Reaction score 37 Jul 10, 2025 #3 within the template, can you tell me what fields need to be adjusted so that i can do that? thank you!
SweetAction 3CX MVP Gold Partner Joined Jan 19, 2018 Messages 3,462 Reaction score 2,321 Jul 10, 2025 #4 I don't have a 46U nearby, but take a phone, make the change in the UI (set to some weird value, like 71), export the config, search the config for that value, and you'll know the line that needs to be added to the template. Reactions: KyriacosS_3CX
rbergthold Silver Partner Advanced Certified Joined Aug 24, 2021 Messages 159 Reaction score 37 Jul 10, 2025 #5 totally straight-forward. i got it from here! thanks Reactions: KyriacosS_3CX
