- Joined
- Aug 9, 2018
- Messages
- 14
- Reaction score
- 0
Can you assist on the possible reasons for the following:-
1) From my 3CX mobile apps, I can intercom a Yealink phone and the person need not pick up the handset to talk. We can hear each other voice.
2) From my Yealink phone extension 0001, I intercom another Yealink extension 0000. There was a beep sound and both phones were connected but unable to hear each other talking.
3) From my Yealink phone extension 0001, I intercom 3CX mobile apps extension 0004. Extension 0004 phone ring just like normal incoming call and ext 0004 needs to press "ANSWER" to answer the call.
In here, what's the difference between an intercom and simply dial into the extension 0004?
I followed the setup instruction below.
Intercom
The intercom feature allows a phone system used to make an announcement to a single extension. In this scenario, the audio is two way, and the called party can respond immediately without picking up the handset. To call a user via the intercom function, add the paging/intercom prefix to the extension number. For example to make an intercom call to extension 100 you should dial: *11100 (if your paging dial code is *11).
You can configure the intercom dial code in “Settings” > “Dial codes” > “Paging.” The user that will use intercom must have the right to do so. Go to “Extensions” > “Edit Extension” > “Rights,” and check the “Can Intercom” option.
Intercom
