Inverted image on webmeeting.
Juan Marriott
Hello, Does anyone knows how to invert the image of the webcam for a webmeeting?
I am trying to use 3CX meetings on a conference room, and the camera is attached upside down below the TV.
Reactions: icns01
There's no option for this nor do we have plans to implement something for this for the moment.
Hi @Juan Marriott
In your case where the cam was mounted upside down, I would suggest to use a 3rd party virtual camera driver, a google search should give you a few options to choose from.
The virtual camera driver allows you to change the settings of the real camera (ie. invert the image) and then you just have to select your virtual camera in webmeeting.
Your camera may also come with its own software that does this (in some cases) but if not then try the above solution.
Reactions: icns01
VOIPEric
