Is it possible to force a password reset on the first login to the 3cx webclient?
5i3cxuser
Is it possible to force a password reset on the first login to the 3cx WebClient
I would like to know if this is a feature that already exist and how to implement this or if it is possible to enable MFA for the WebClient.
To answer your questions,
You can not force a password change, the only way to change the password is within 3CX Management console
Webclient does not support MFA
Reactions: ChrisC_3CX
To add to what Saqqara said regarding MFA, in v18 we have introduced SSO for webclients so MFA will be available via the platform used for SSO.
You could modify the default Welcome Email and remove the WebClient credentials from the email to force users to use SSO to login.
Yes, an 10-digit password will exist, but remember that WebClient logins are subject to blacklisting after 3 wrong attempts.
I accept that this is not what you want (although very close I think...), but I can't see the vulnerability.
megalmazan
