Is it possible to SSH into 3CX Debian? Qemu-guest-agent?
mobilityproject
I can't seem to figure out how to SSH into my new Debian 3CX install (from ISO). Is there a default user name or password? I'm running on Proxmox and would like to install the Qemu-guest-agent. Thanks
HI mobilityproject,
If you installed from the 3CX Debian ISO you will have put the password in when the setup was done, there is no default password.
The username is however just 'root'.
I don't recall making a different password then the one I use to log into the web portal. Perhaps I did. Is there anyway to reset the SSH password from the web portal?
The SSH password is located at the OS level and cannot be changed from the management console. If you used the 3CX ISO a root password was requested during the installation as we do not set a password for the OS
maurin.roffler
