Is there a downloadable manual?
greychain
Gold Partner
I really appreciate the online help, but some customers need manuals they can ignore. Is there a downloadable version?
Hi, the content in manuals, guides are updated from version to version, so in this way it is better keeping them online.
Anyway, from your browser you can try to print and save it as PDF if you want a file with you.
There are also extensions to do this that you can have in your browser.
Have a great day!
Kindly note that the required information can be located in the following links below, regardless you are an user or an admin:
User Manual - basic features
Admin Manual - detailed usage information
Thank you
Yes I was trying to avoid work
Jake_Southern
