Solved Is v18-vc-qos.3cx.net still applicable to v20?
SteveITS
3CX MVP
"v20-vc-qos.3cx.net" doesn't seem to exist, just checking if v18-vc-qos.3cx.net is still going to be used.
(This isn't our system but it's the only one that allows us to post in this category.)
Hi there.
Are you referring to the specific FQDN domain?
Yes, it was to be used for QoS/traffic shaping for web meetings. I meant, will it change with version 20.
So the MCU cluster system is the same in v20, so the link is still valid for both versions.
For now, no intention to change it, however, it can be the case in the future.
Hi there, the v18-vc-qos.3cx.net is useable for both v18 and v20 PBXs. At this point in time we prefer not to change the FQDN even if it is confusing as doing so would invalidate already configured QoS setups made by users such as yourself.
Reactions: Ecki and Evolute IT
Thank you both.
Reactions: OlegR_3CX
You are welcome and have a great weekend ahead!
jasonkkrause
