Solved Issue renewing ssl certificate
Septech2
On a 20.0 Update 2 (Build 715 Release) pbx, self hosted, the SSL certificate is not renewing, though it's expired.
I tried manual renew with CLI ssh : KO
Nginx retstart : KO
Server reboot : KO
Renewal logs shows a message which may be about sql connection " peer authentication failed for user phonesystem"
Does it ring a bell for you ?
Thanks !
Merci !
Firewall check is OK, dns resolution OK
Hi, spontaneous repair...
You can close the post
tom.walker@blackcountryra
