Issue with DISA a no password
NellyB
Hi guys, I'm running an Elastix PBX v 2.0.0. I have a DISA set up that I would like to use no PIN.
When I set it up with a PIN it operates perfectly. However, when I set it with no PIN the call comes in and goes to the DISA as expected but I hear no audio. DTMF codes are nore recognised either:
-- Executing [02032980010@from-trunk:6] Goto("SIP/hextel-hello-00001e4b", "disa,3,1") in new stack
-- Goto (disa,3,1)
-- Executing [3@disa:1] Set("SIP/hextel-hello-00001e4b", "_DISA="disa,3,newcall"") in new stack
-- Executing [3@disa:2] Set("SIP/hextel-hello-00001e4b", "_DISACONTEXT=from-internal") in new stack
-- Executing [3@disa:3] Set("SIP/hextel-hello-00001e4b", "_KEEPCID=TRUE") in new stack
-- Executing [3@disa:4] Set("SIP/hextel-hello-00001e4b", "_HANGUP=Hg") in new stack
-- Executing [3@disa:5] Set("SIP/hextel-hello-00001e4b", "TIMEOUT(digit)=5") in new stack
-- Digit timeout set to 5.000
-- Executing [3@disa:6] Set("SIP/hextel-hello-00001e4b", "TIMEOUT(response)=10") in new stack
-- Response timeout set to 10.000
-- Executing [3@disa:7] DISA("SIP/hextel-hello-00001e4b", "no-password,disa-dial") in new stack
== Spawn extension (disa, 3, 7) exited non-zero on 'SIP/hextel-hello-00001e4b'
I have upgraded the DISA modlue to the latest version - 2.7.0.1 - but get the same result. When I add a PIN to the DISA it works fine.
Any ideas?
Many thanks,
Neil
A little more info:
When using a PIN, the call is dropped into DISA:
-- Executing [02032980010@from-trunk:4] Set("SIP/hextel-hello-00001e51", "__CALLINGPRES_SV=allowed_not_screened") in new stack
-- Executing [02032980010@from-trunk:5] Set("SIP/hextel-hello-00001e51", "CALLERPRES()=allowed_not_screened") in new stack
-- Executing [02032980010@from-trunk:6] Goto("SIP/hextel-hello-00001e51", "disa,2,1") in new stack
-- Goto (disa,2,1)
-- Executing [2@disa:1] Authenticate("SIP/hextel-hello-00001e51", "3624,") in new stack
-- <SIP/hextel-hello-00001e51> Playing 'agent-pass.gsm' (language 'en')
-- <SIP/hextel-hello-00001e51> Playing 'vm-goodbye.gsm' (language 'en')
== Spawn extension (disa, 2, 1) exited non-zero on 'SIP/hextel-hello-00001e51'
But without a PIN it gets routed through to "no-password,disa-dial"
Apollo Cloud
