- Joined
- Feb 9, 2010
- Messages
- 34
- Reaction score
- 0
everything was working fine with this elastix 1.6.2-33 (except for faxes, but that's another topic). it uses an HP Server 300 Gb iSCSI, Atcom 1 E1 Card (mISDN)
now when I try to place an outbound call, I get this:
-- Executing [55240001@from-internal:1] Macro("SIP/9026-00000001", "user-callerid|SKIPTTL|") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/9026-00000001", "AMPUSER=9026") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("SIP/9026-00000001", "0?report") in new stack
-- Executing [s@macro-user-callerid:3] ExecIf("SIP/9026-00000001", "1|Set|REALCALLERIDNUM=9026") in new stack
-- Executing [s@macro-user-callerid:4] Set("SIP/9026-00000001", "AMPUSER=9026") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/9026-00000001", "AMPUSERCIDNAME=9026") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/9026-00000001", "0?report") in new stack
-- Executing [s@macro-user-callerid:7] Set("SIP/9026-00000001", "AMPUSERCID=9026") in new stack
-- Executing [s@macro-user-callerid:8] Set("SIP/9026-00000001", "CALLERID(all)="9026" <9026>") in new stack
-- Executing [s@macro-user-callerid:9] ExecIf("SIP/9026-00000001", "0|Set|CHANNEL(language)=") in new stack
-- Executing [s@macro-user-callerid:10] GotoIf("SIP/9026-00000001", "1?continue") in new stack
-- Goto (macro-user-callerid,s,19)
-- Executing [s@macro-user-callerid:19] NoOp("SIP/9026-00000001", "Using CallerID "9026" <9026>") in new stack
-- Executing [55240001@from-internal:2] Set("SIP/9026-00000001", "_NODEST=") in new stack
-- Executing [55240001@from-internal:3] Macro("SIP/9026-00000001", "record-enable|9026|OUT|") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("SIP/9026-00000001", "1?check") in new stack
-- Goto (macro-record-enable,s,4)
-- Executing [s@macro-record-enable:4] AGI("SIP/9026-00000001", "recordingcheck|20120608-111354|1339175634.3") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
recordingcheck|20120608-111354|1339175634.3: Outbound recording enabled.
recordingcheck|20120608-111354|1339175634.3: CALLFILENAME=OUT9026-20120608-111354-1339175634.3
-- AGI Script recordingcheck completed, returning 0
-- Executing [s@macro-record-enable:999] MixMonitor("SIP/9026-00000001", "OUT9026-20120608-111354-1339175634.3.wav||") in new stack
-- Executing [s@macro-record-enable:1000] Set("SIP/9026-00000001", "CDR(userfield)=audio:OUT9026-20120608-111354-1339175634.3.wav") in new stack
== Begin MixMonitor Recording SIP/9026-00000001
-- Executing [55240001@from-internal:4] Macro("SIP/9026-00000001", "dialout-trunk|2|55240001||") in new stack
-- Executing [s@macro-dialout-trunk:1] Set("SIP/9026-00000001", "DIAL_TRUNK=2") in new stack
-- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/9026-00000001", "0?sub-pincheck|s|1") in new stack
-- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/9026-00000001", "0?disabletrunk|1") in new stack
-- Executing [s@macro-dialout-trunk:4] Set("SIP/9026-00000001", "DIAL_NUMBER=55240001") in new stack
-- Executing [s@macro-dialout-trunk:5] Set("SIP/9026-00000001", "DIAL_TRUNK_OPTIONS=tr") in new stack
-- Executing [s@macro-dialout-trunk:6] Set("SIP/9026-00000001", "OUTBOUND_GROUP=OUT_2") in new stack
-- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/9026-00000001", "0?nomax") in new stack
-- Executing [s@macro-dialout-trunk:8] GotoIf("SIP/9026-00000001", "0?chanfull") in new stack
-- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/9026-00000001", "0?skipoutcid") in new stack
-- Executing [s@macro-dialout-trunk:10] Set("SIP/9026-00000001", "DIAL_TRUNK_OPTIONS=") in new stack
-- Executing [s@macro-dialout-trunk:11] Macro("SIP/9026-00000001", "outbound-callerid|2") in new stack
-- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/9026-00000001", "0|SetCallerPres|") in new stack
-- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/9026-00000001", "0|Set|REALCALLERIDNUM=9026") in new stack
-- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/9026-00000001", "1?normcid") in new stack
-- Goto (macro-outbound-callerid,s,6)
-- Executing [s@macro-outbound-callerid:6] Set("SIP/9026-00000001", "USEROUTCID=") in new stack
-- Executing [s@macro-outbound-callerid:7] Set("SIP/9026-00000001", "EMERGENCYCID=") in new stack
-- Executing [s@macro-outbound-callerid:8] Set("SIP/9026-00000001", "TRUNKOUTCID=23299000") in new stack
-- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/9026-00000001", "1?trunkcid") in new stack
-- Goto (macro-outbound-callerid,s,12)
-- Executing [s@macro-outbound-callerid:12] ExecIf("SIP/9026-00000001", "1|Set|CALLERID(all)=23299000") in new stack
-- Executing [s@macro-outbound-callerid:13] ExecIf("SIP/9026-00000001", "0|Set|CALLERID(all)=") in new stack
-- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/9026-00000001", "0|SetCallerPres|prohib_passed_screen") in new stack
-- Executing [s@macro-dialout-trunk:12] ExecIf("SIP/9026-00000001", "0|AGI|fixlocalprefix") in new stack
-- Executing [s@macro-dialout-trunk:13] Set("SIP/9026-00000001", "OUTNUM=55240001") in new stack
-- Executing [s@macro-dialout-trunk:14] Set("SIP/9026-00000001", "custom=AMP") in new stack
-- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/9026-00000001", "0|Set|DIAL_TRUNK_OPTIONS=M(setmusic^)") in new stack
-- Executing [s@macro-dialout-trunk:16] Macro("SIP/9026-00000001", "dialout-trunk-predial-hook|") in new stack
-- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/9026-00000001", "") in new stack
-- Executing [s@macro-dialout-trunk:17] GotoIf("SIP/9026-00000001", "0?bypass|1") in new stack
-- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/9026-00000001", "1?customtrunk") in new stack
-- Goto (macro-dialout-trunk,s,21)
-- Executing [s@macro-dialout-trunk:21] Set("SIP/9026-00000001", "pre_num=AMP:mISDN/1/") in new stack
-- Executing [s@macro-dialout-trunk:22] Set("SIP/9026-00000001", "the_num=OUTNUM") in new stack
-- Executing [s@macro-dialout-trunk:23] Set("SIP/9026-00000001", "post_num=") in new stack
-- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/9026-00000001", "1?outnum:skipoutnum") in new stack
-- Goto (macro-dialout-trunk,s,25)
-- Executing [s@macro-dialout-trunk:25] Set("SIP/9026-00000001", "the_num=55240001") in new stack
-- Executing [s@macro-dialout-trunk:26] Dial("SIP/9026-00000001", "mISDN/1/55240001|300|") in new stack
-- Called 1/55240001
P[ 1] **** Received CAUSE:44, restarting channel 1
P[ 1] Sending Restarts on this port.
P[ 1] Restarting and cleaning channel 1
P[ 1] Restarting channel 1
== Everyone is busy/congested at this time (1:0/0/1)
-- Executing [s@macro-dialout-trunk:27] Goto("SIP/9026-00000001", "s-CHANUNAVAIL|1") in new stack
-- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] GotoIf("SIP/9026-00000001", "1?noreport") in new stack
-- Goto (macro-dialout-trunk,s-CHANUNAVAIL,3)
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:3] NoOp("SIP/9026-00000001", "TRUNK Dial failed due to CHANUNAVAIL (hangupcause: 44) - failing through to other trunks") in new stack
-- Executing [55240001@from-internal:5] Macro("SIP/9026-00000001", "outisbusy|") in new stack
-- Executing [s@macro-outisbusy:1] Playback("SIP/9026-00000001", "all-circuits-busy-now|noanswer") in new stack
-- <SIP/9026-00000001> Playing 'all-circuits-busy-now' (language 'en')
-- Executing [s@macro-outisbusy:2] Playback("SIP/9026-00000001", "pls-try-call-later|noanswer") in new stack
-- <SIP/9026-00000001> Playing 'pls-try-call-later' (language 'en')
but I did not change anything from the original working configuration. If someone has some experiencie with this. I will appreciate. Regards,
