IVR Forward Mobile phone Failed
lanhiohoppo
I am IT System, I am configuring the 3cx system
The idea is that when someone from outside calls the switchboard, it will be transferred directly to the internal number (extension) of the person in charge. After 3 beeps, if no one picks up the phone, the operator will say hello and forward to the number. mobile phone
Can anyone help me, thank you
Hi, if the calls are entering to the extension then you can configure the forwarding rules if no answer to the Mobile Number.
Please check that there is an outbound rule that can be used to dial the Mobile Number too.
Have a great day!
Have a great day!
I am currently trying the Standard Annual version and the trial has expired. Will this affect the quality of the experience, call quality and stability of the 3CX system?
No, this is something that you should review in the network, internet connection, hardware used, etc. The system should be running with then supported hardware recommendations.
Jake_Southern
