- Joined
- Aug 25, 2021
- Messages
- 7
- Reaction score
- 1
I am forwarding calls from Google Voice to a Callcentric #, which rings a Callcentric extension being used as a 3cx trunk.
If I dial the Callcentric number directly, I get the 3cx IVR. Things work as expected.
If I dial the Google Voice number, I only hear ringing. The IVR never picks up.
3cx shows it "answered" for 24 seconds
the following error shows in the 3cx activity log:
01/19/2022 2:45:02 AM - [CM503003]: Call(C:51): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
If I dial the Google Voice number with 3cx set to forward to a Ring Group or an Extension instead of an IVR, things work fine.
It was formerly an NFR Pro with call queues. Possibly some now-hidden settings causing problems?
So, guessing, the DID Callcentric is passing when Google Voice forwards to it is confusing 3cx. Is there a way to set 3cx to ignore the Callcentric DID and just route based on the trunk?
It's a 3cx hosted instance. I couldn't find anywhere showing me the SIP
Edit: 18.0 Update 2 (Build 314), 3cx Hosted
