IVR Reporting/Statistics
ivrhelp
Greetings,
Is there a report that provides IVR statistics to help identify call dispositioning and self-service opportunities? The metrics below are examples of statistics that can be produced from the use of an IVR. Is there a report that provides similar metrics?
% Complete
The percentage that were complete.
% Incomplete
The percentage that were incomplete.
% Transferred
The percentage that were transferred.
Average Call Dur (Sec)
The average amount of time duration for which a customer speaks to an agent.
Average Call Dur Bef Transfer (Sec)
The average time duration for which a caller speaks to an agent before transfer.
Avg Comp Time (Sec)
The average amount of time for completion.
Avg Hits/Call
The average number of times a prompt is accessed for each call.
Avg NI/Hit
Average number of No Input (NI) errors for a call. NI occurs when the IVR is asking a question and the caller does not respond within the configured time.
Avg Prompt Dur (Sec)
The average amount of time duration for which a customer stays on a prompt.
Avg Time Before Hang-up (Sec)
The average amount of time before a customer terminates the call.
Avg Time Before Transfer (Sec)
The average amount of time before an agent transfers the call.
The total duration, in seconds, of a call.
Calls
The number of calls sent to agents.
Calls < 10 Sec
The number of calls sent to agents with a duration under 10 seconds.
Calls Contained
The number of calls that were handled by a single agent.
Calls Transferred
The number of calls that were transferred to another agent.
Completed
The number of calls that were completed.
Hang-ups
The total number of customer-initiated hang-ups.
Hits
The number of times a prompt is accessed.
Incomplete
The number of calls that were terminated before completion.
IVR Duration (Sec)
The total duration, in seconds, that a customer spends using IVR prompts.
Minutes
The number of minutes for a call.
NI Errors
Total number of No Input (NI) errors. NI occurs when the IVR is asking a question and the caller does not respond within the configured time.
NI Exits
Total number of times that callers disconnect after a No Input error. NI occurs when the IVR is asking a question and the caller does not respond within the configured time.
NM Errors
Avg number of No Match (NM) errors per call. NM occurs when the IVR is asking a question and the caller’s response does not correspond with expected responses.
NM Exits
Total number of times that callers disconnect after a No Match (NM) error. NM occurs when the IVR is asking a question and the caller’s response does not correspond with expected responses.
Non-VUI Errors
Any other type of error at prompt level which is not NI or NM.
Prompt Dur (Sec)
The time duration in seconds for which a customer remains on a prompt.
Prompt Hits
The number of times a prompt is accessed by a call. For example, the value is 2 if the same call hits the same prompt twice.
Started
The number of calls that were started.
Task Dur Sec_Complete
The time duration in seconds for which a task is completed.
Task Dur Sec_Incomplete
The time duration in seconds before a task is terminated.
Task Dur Sec_Transferred
The time duration in seconds before a task is transferred.
Task Duration
The amount of time duration for a task to complete.
Total Call Duration
The total amount of time duration for a call.
Total Entries
The total number of times customers enter a prompt.
Total Exits
The total number of times customers exit a prompt.
Transfer Duration (Sec)
The total duration, in seconds, that a customer remains in call transfer.
Transferred
The number of tasks that are transferred to another agent.
Bluebox Global
