Java Installation
arafath
Intermediate Cert.
Dear 3CX Support,
I need an expert advice from you.
I have my 3CX Running on windows, Is there any issue installing Java latest version.
Management console does not need java
Nor do any of the clients. You can safely install the version of Java you need.
Hello @arafath
As above Java is not used by the 3CX phone system but we do recommend that the PBX machine should be dedicated for the phone system and not used to run additional software.
gmacinit
