Joining the web conference as an audio-only participant
RobArnett CNR
Does this take up the Lines available (Say 8 Line License) or does it count towards the 250 Web Conference Participants?
Using the dial-in will use 2 SC per joined person.
1 call from the user (external or internal) to the 700 extension, 1 call from the 700 to the WebMeeting trunk (connection to your meeting ID).
It also count as a participant in the WebMeeting, which is limited to either 250 or the limit your license has.
If you only have an 8 SC lic., then you can only have 4 People call in externally?
Yeah, or even internally. You have to take that into consideration.
Unless that changed. I would test it. It might be using 2 SC for the 1st person then only 1 SC each other. Since technically, you could need only the call between the bridge and the 700; then the calls between users and 700 ext. This would take less SC.
@StefanW @JohnS_3CX Can someone confirm or tell me if I am wrong?
Okay so I did some testing and the case is this:
First Caller calls in to audio side and there are 2 calls taken up.
Next Caller takes up one additional call and so on. So if you have 8 SC, then you can have 7 External Callers.
This is not how the Website explains this:
https://www.3cx.com/pbx/web-conferencing/
With web conferencing you can hold live meetings, conferencing, presentations and training, online, via TCP/IP connections. Connecting to the conference is simply done by telephone or by making use of a computer’s speakers and microphone through a VoIP connection. Web conferencing can transform the way you communicate and collaborate within your company and enables you to offer next-level customer support.
3CX’s WebRTC-based web conferencing feature is an easy-to-use solution that is included in all editions of 3CX for free for up to 250 participants.
This makes this solutions less affordable then the competition. Like Zoom or WebEx.
Excellent. That makes more sense! I will know now!
Why do you say that? 250 participants are a lot and only dial-in are counted in SC. You can have 250 web participants with audio from their computer and you won't use any SC.
I understand that, but the Website says simply done by Telephone, doesn't mention that you have to have that many SC lics to accomplish this. Most standard business users do not have Headsets to be able to attend via a PC.
I agree. It should be written somewhere, but it is the 3CX way. You pay per SC. If you know you have many users using the dial-in, then get a bigger license.
Hi Rob
Sorry it wasn't clear enough, I will attempt to provide some clarifications:
The site currently states "3CX’s WebRTC-based web conferencing feature is an easy-to-use solution that is included in all editions of 3CX for free for up to 250 participants."
This feature is included for free in all editions of 3CX, labelled for Web based conferencing. Look under the Office Productivity heading here to see the seats offered per license type, but you get 25 as a bare minimum: https://www.3cx.com/ordering/pricing/
As for anything that has to do with SIP-based calls (and that that includes dial in participants) our pricing model is based on the number of simultaneous calls you buy and this is how we make money with our product.
So any participant that dials in will use up a sim. call, and the webmeeting bridge (which is also a SIP endpoint internally) will also use up one call to do the job of connecting the callers to the the webmeeting servers.
If you choose to use web-based conference only, you pay nothing basically for up to 25 seats. If you want to use anything that has to do with SIP calls, then you get up to 8SC for free in V16.
Finally if all the above is not enough for your needs, then it's time to purchase a license. We will be happy to clarify any questions you have before buying a license.
Hassan Murasan
