Language settings?
killmasta93
I was wondering if someone could shed some light?
So I have Elastix installed in English and all the ext have to be in Spanish. I had to put manually each ext the language es but I was wondering if I can put somewhere in the sip.config language=es that means that any ext would be in Spanish? or is it possible something like that?
Thank you
Go to PBX - Freepbx - Settings - Asterisk Sip Settins
Advanced General Settings :
Set parameter : language = es
Thank you for the reply, But its odd getting this error any idea?
Thank you see pics
Thank you i figured it out I needed to go to sip.conf and add language=es
Eveything is now in spanish
Thank you
At first you need to edit sip_general_custom.conf and delete all parameters inside this file.
This error appears for avoid to have a conflict with some files.
Next, put this parameters within sip.conf is a bad idea.
Look at the part in the top of file.
Do NOT edit this file
And you, you have edited this file!
Once you have deleted all datas into sip_general_custom.conf, you could save asterisk sip settings without any problem.
This is the good way.
Regards
True But i guess im little less fond on deleting files rather then editing :)
It did get the job done :)
RRusev
