Solved License for Inbuilt Failover
haianhtran
Hi 3CX team,
My customers are trying to set up an backup switchboard: "active - standby" .I see the Enterprise edition has the "Inbuilt Failover" feature. I understand that to run the HA (Hight Availability) mechanism, two server clusters are required. So I want to ask that my customers need to buy 1 license or 2 licenses to implement HA?
Thanks!
3CX enterprise license allows you to run the same license on two machines,
Yes, you can run HA using Pro or Std, but you need to purchase two separate licenses.
The extra benefit with Enterprise, is using 3cx fqdn dns update 5 mins, where Pro / Std is 6 hrs
Reactions: haianhtran
3CX enterprise license allows you to run the same license of two machines,
Thanks so much!
ICTSupport@bedfordgirlssc
