License question
anglenora2022
I have signed up for the free license and am trying to get it to appear in our partner portal, is there any way to do this as its not a paid license?
Have you built the system with the free Licence?
Inside the system you will need to associate the system with your Partner ID on the right hand side of the Systems Dashboard.
As @pact mentioned you will need to do this through the management console after the system is installed. The option is on the dashboard under the information column.
gmacinit
