Limit Disk Quota for Voicemail
oscquin
Hello Folks, I have the following questions:
1. Is there any way to set up a disk quota for mailboxes in elastix?
2. is there a way to tell the system to erase the oldest mailboxes when this quota is reached?
Thanks,
Brgds,
This is a bit different but I would configure a daily cron job which would delete the files (in the voicemail folder) that are older than x amount of days.
If you think this could be an alternative, check this link:
http://www.howtogeek.com/howto/ubuntu/d ... -on-linux/
I think this is an easy way to control the amount of voicemails.
yarusemiKK
