Limit time to outbound call
oscquin
Hello, I'm trying to limit time for outbound calls for certain contexts under elastix 2.3
I have a context called COS03 wich I want to limit to 3 minutes. I have created the context and in extensions_custom.conf I have added:
[outrt-3-custom] ; COS03-custom
;include => outrt-3-custom
exten => _9XXXXXXXX,1,Macro(user-callerid,SKIPTTL,)
exten => _9XXXXXXXX,n,Noop(Calling Out Route: COS03Custom)
exten => _9XXXXXXXX,n,Set(MOHCLASS=${IF($["${MOHCLASS}"=""]?default:${MOHCLASS})})
exten => _9XXXXXXXX,n,Set(_NODEST=)
exten => _9XXXXXXXX,n,Macro(record-enable,${AMPUSER},OUT,)
exten => _9XXXXXXXX,n,Macro(dialout-trunk,1,9${EXTEN:1},trL(180000:60000:10000),)
exten => _9XXXXXXXX,n,Macro(outisbusy,)
; end of [outrt-3-custom]
but the L option seems to not work. any ideas? thanks in advance.
Hi all.
Read the top of file into extensions_additional.conf.
Code:
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make    ;
; custom modifications, details at: http://freepbx.org/configuration_files       ;
extensions_custom.conf seems the good file to be used.
Yes thanks....of course it is bad to use the _additional.conf
....I tested in the extensions_additional.conf to determine if the time limit feature is working or not....it does.
I think there is a problem with the extensions_custom.conf in version 2.3
Can you advise if you are using custom contexts in 2.3 extensions_custom.conf?
I have been unable to get them to work
Cheers
There's no problem with extensions_custom.conf with ELastix 2.3.0, sure.
From my side, within my RoomX project, i use a custom context, and all works fine.
For example, at first line, i included this:#include extensions_roomx.conf
Next, i created a custom file extensions_roomx.conf with this:
Code:
[from-roomx]
include => calendar-event
include => weather-wakeup
include => app-dnd-toggle
include => ext-dnd-hints
include => app-speakingclock
include => app-vmmain
include => clean
include => minibar
include => reception
include => Roomx-dialout
[clean]
exten => _*36,1,NoOp( ====> Room ${CALLERID(num)} is Clean now <==== )
exten => _*36,n,MYSQL(Connect connid localhost root asterisk roomx)
exten => _*36,n,MYSQL(Query resultid ${connid} UPDATE `rooms` SET `clean`='1' where `extension`='${CALLERID(num)}' )
exten => _*36,n,MYSQL(Clear ${resultid})
exten => _*36,n,MYSQL(Disconnect ${connid})
exten => _*36,n,playback(beep)
exten => h,1,Hangup()
.Etc.....
Hmmm, be careful at the headers like [from-custom-interal] and else.....
Maybe just add a : include => COS03 into the curent context.
Thanks...just so I understand:
you add the line:
in to the extensions_custom.conf?
yes, at first line.
But it's just an example.
In this example, all rooms has from-roomx instead of from-internal.
If you look at extensions_custom.conf, you can dial some functions like 1234.
So you could add an include => COS03 and declare this context somewhere into extension_custom.conf under from-custom-internal for example.
We have to start from the begining:
1. Is the right way for custom contexts to be included in extensions_custom.conf?
2. extensions_additional.conf contexts already include the "context-custom" line so when you create the "context-custom" context in extensions-custom.conf, asterisk automatically references it right?
3. could this be any kind of bug?
oscquin,
A couple things:
1) According to my elastix test server: asterisk-1.8.12.0-0; freePBX-2.8.1-10
on Macro(dialout-trunk,1,9${EXTEN:1},trL(180000:60000:10000),) the third argument is for checking if the outbound route needs or not a PIN to dial out, not to add any option to the dial application.
2) If I'm not mistaken, on an upper level the context is called directly, since it has a pattern match, it will not use it from the custom part that you have edited, it will use the custom part if it has another extension pattern.
3) What I would do is the following:
write the same context name on extensions_override_elastix.conf (or extensions_override_freepbx depending on your elastix version) and use the TRUNK_OPTIONS variable.
[outrt-3]
exten => _9XXXXXXXX,n,Set(TRUNK_OPTIONS=L(180000:60000:10000)${TRUNK_OPTIONS})
exten => _9XXXXXXXX,n,Macro(dialout-trunk,1,9${EXTEN:1},)
4) Execute:
asterisk -rx "module reload"
Thanks jgutierrez, it's solved thanks to your solution, placing the context in extensions_override_elastix.conf make it work.
I still would like to understand why it does not work under extensions_custom.conf
Thanks again.
Thanks Jorge, legendary as usual
Cheers
yarusemiKK
